Re: International 2000 Loader on a 240 utility
Posted by Jim Becker on December 29, 2009 at 08:04:11 from (173.57.141.22):
In Reply to: International 2000 Loader on a 240 utility posted by cleb on December 27, 2009 at 19:14:46:
My point wasn't that the loader had 240 brackets with it. It was that IH designed the loader so it COULD fit the 240 and made the correct brackets. The 1501 was not designed for the 240 and IH didn't make brackets for it. It is easier to build a missing part than it is to reengineer two things that weren't designed together in the first place.
Probably doesn't matter now anyway. For $300 that loader is probably long gone.
