Pull several sparkplugs and pour in about 2 teaspoons of gas on of the top of the pistons and reinstall the plugs. Then see if the engine will fire when you try to start it. If it does you're not getting any gas to the engine. You need to check fo gas flow to the carb by didconnecting the gas line at the carb. Should have a full stream of gas. Catch the gas in a clean container. Good flow there remove the tube fitting in the carb where your gas line connects. Should be a screen behind that fitting. Remove the screen and see if it has a load of rust or dirt in it. If that's clean your carb probably needs a good cleaning. It may be gummed up from old gas. We call this the process of elemination. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
