Re: M Rebuild
Posted by r4etired on December 29, 2009 at 18:27:14 from (166.227.136.180):
In Reply to: M Rebuild posted by ChrisMO on December 29, 2009 at 07:24:14:
Each person has there own opinion on repairing old tractors.Mine is it all depends on what you expect the tractor to do after rebuilding. If you are going to plow a couple hundred acres and continue to work it hard I would say you could justify a 1200-1500 dollar rebuild. If it is going to rake hay or run an auger go the cheap route. I hate to spend more than the value of the tractor to rebuild one.
