Re: H - Frozen Trottle
Posted by Janicholson on December 29, 2009 at 19:52:22 from (69.178.223.32):
In Reply to: H - Frozen Trottle posted by Dan Dodge on December 29, 2009 at 19:40:12:
Either governor linkage, or throttle linkage. If the throttle lever is not moving, check all external connections from lever to the governor. If the throttle moves but does nothing to change the speed, it is internal icing. JimN
