And, the adjustment of the bottom screw which holds the band centered is important. Once you get the adjustment close adjust the screw per specifications to allow the band to not rub on the top or bottom of the drum until the pedal is depressed.
If you're hitting the stop you really need to pull the cover if you haven't already to make sure the lining is not gone. It's expensive to get them relined anymore, seems like the last time I checked new bands were just as cheap as relining.
If you have adequate lining then you should be able to adjust the screw which goes into the spring to get the pdeal travel you want, unless parts have been replaced with ones which looked right but are from a different model.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
