Re: IH 464 can't keep running.
Posted by dannyra on December 30, 2009 at 13:17:59 from (174.39.231.182):
In Reply to: Re: IH 464 can't keep running. posted by El Toro on December 30, 2009 at 10:04:17:
These carbs don't have the main jet adjusting screw. It's controlled with the electronic shutoff.
The only adjustment screw on these carbs is the idle screw.
If I had the tractor here I'd take a picture of the carb and post.
The mechanic thinks he found another carb he can try. Then we'd at least know if the issue is confined to the carb.
