A used idler gear should be easy to find, they only drive the governor and usualy are in pretty good shape unless something else fails and tears it up. Sometimes the bearing in center of hub and bearing shaft gets worn to much. Any replacement camshaft gear now should be based on the latest one IH cam out with in 1955, # 6760DB. When you get yours out and if you can see the # on the gear hub, it may have just a D on the end. If it has DA or DB, it was replaced sometime. Just to make sure about the gears refered to, If you just removed the pump. Gear you can see in the hole is the camshaft gear.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
