Re: Key Ignition
Posted by tractorsam on December 30, 2009 at 18:31:00 from (99.192.62.231):
In Reply to: Re: Key Ignition posted by Jack D. L. on December 30, 2009 at 16:53:48:
It all depends what you want at the end of the day. If you want to put it back to original then all of the correct parts can be found. If you simply want something that works, anything that can be wired together could be the answer (and believe me, with some of the stuff I've stipped off tractors I've bought - anything is possible!). If you want original or simple and functional you can find someone on this board who can help you wire it. So whether the switch for a 240 will work is really up to you. Sam
