Re: snow plow question super A
Posted by Adrian Billheimer on December 30, 2009 at 19:38:13 from (173.86.55.73):
In Reply to: snow plow question super A posted by RJV on December 30, 2009 at 19:13:38:
Ron, you are correct at the mounting point on the torque tube by the starter, I'm not sure about reversing the drawbar and mounting from there, if it was a solid axle like Cs and larger I would say it is the best place to mount the plow, but I would be a little leary about mounting on those dropped axles. You may be ok pushing snow, but if you hit a rock in the driveway or other hidden obstacle you could break a cast part that will be expensive to fix or replace.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
