Super A elec sys
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Sam Scott on April 27, 2000 at 19:08:16 from (205.188.199.178):
Just started working on a Super A I recently bought. Need to know if Pos or neg ground. Took cap off from distributor, no points, is this system a Mag? Also,took all plugs out, grounded a couple of them and I get no spark when cranking engine. Is the wire to the distributor supposed to be hot when switch is on?
Thanks, if I can
get past the electrical system the rest is a piece of cake.
Post A Followup
: Re: Super A elec sys
