'48 Cub hydraulics question.
Posted by BenB on December 30, 2009 at 22:03:45 from (74.42.97.240):
I have an early 48 cub with no hydraulics. It only has the spring assisted hand lift on it currently. What I'd like to do is get all the components to convert it to having a fully functioning OEM hyd. lift system so I can get a blade setup for the front to push snow with. What all is involved? I know I'd need a hyd pump and valve block, but if I found them off of a newer parts tractor would they work on mine since it never had them before? Thanks in advance for any information and advice!
-Ben
