Re: Keyed ignition wiring
Posted by Jack D. L. on December 31, 2009 at 15:36:47 from (216.19.24.42):
In Reply to: Re: Keyed ignition wiring posted by Andrew Z on December 31, 2009 at 13:36:30:
The key is an on/off switch. I'm attaching a picture of the back. It looks like the push/pull has been abandoned. It is started with the starter switch control rod that is pulled to start the tractor in place of the solenoid. The Cub has a key switch and you turn that on and pull the starter switch control rod to start it. This is the same configuration.
