Re: points
Posted by Shawn in PA on December 31, 2009 at 18:44:57 from (72.23.162.33):
In Reply to: Re: points posted by fred kobs on December 31, 2009 at 18:20:53:
The whole system is rebuilt, works and runs great...12V conversion, all new wires, 12V internally ballasted coil. The distributor shaft is tight, new bushings. I know that leaving the switch on can burn them, and I avoid that. I did not file them when I put them in. I'll remember that this time. The only reason I noticed was i switched out the springs on the distributor weights to lighter ones. Thats when I noticed the points were cooked. It runs alot, but not any more than normal for a tractor. Its not a big deal cause they are cheap and quick, but I thought they'd last for yrs, not months. I did not lube or polish the breaker cam either...hmmm.
