Re: Re: Three pt. hitch for H
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Roger on April 27, 2000 at 20:40:45 from (209.224.35.207):
In Reply to: Re: Three pt. hitch for H posted by MrG on April 27, 2000 at 09:17:59:
I also have a aftermarket 3 point hitch on my Super H that I have had for about 20 years. It is mounted off the drawbar mounts on the axle. The hitch is operated off the tractor hydraulics. The problem is that adjusting the depth on things like plows, mowers, etc. is tricky because you just have to look back at the cylinder position to get the right depth/height. I also have a 3 point hitch log splitter that I drive off the tractor hydraulics. The problem with this setup is that you have to convert the single acting hydraulic system to a two way system. The second problem is that the Farmall hydraulics of that era only have a max pressure of 700 - 800 psi which is marginal unless you have a big cylinder on your log splitter. Mine works OK on oak and other wood that is easy to split, but if you are splitting elm or something hard to split it doesn't work very well. Roger
Post A Followup
: Re: Re: Re: Three pt. hitch for H
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
