Re: Is my float sticking?
Posted by Bob M on January 01, 2010 at 10:36:37 from (74.74.143.242):
In Reply to: Is my float sticking? posted by Faster346 on January 01, 2010 at 10:03:44:
Good chance trash (grain of rust, a bit of pipe tape or similar) has caught in the float valve seat so it won't seal tight.
Suggest dropping the bowl then removing the float, needle and seat and blowing it out. Also check for a gas-logged (punctured) float pontoon, a loose float hinge (so float binds on the bowl housing) or a damaged needle/seat.
Before reassembling turn on the gas and let it flow for a few seconds to flush the fuel line.
And make it a practice to ALWAYS shut off the gas at the sediment bowl when done using the tractor for the day. Might save yourself losing a tankful of fuel someday!
