Posted by D Slater on January 01, 2010 at 12:23:55 from (72.65.142.52):
In Reply to: Re: I 6 pinion gears posted by superbad on January 01, 2010 at 11:30:21:
Get the 6 ring gear and pinion shaft with bearing and bearing cage complete. Install in a M the same as you would the original ring and pinion. Can use the M mainshaft bearing, but the 6 bearing cage is needed to get the main shaft set to the proper depth in the 6 ring gear.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
