Re: Is my float sticking?
Posted by 440roadrunner on January 01, 2010 at 12:48:04 from (76.178.187.6):
In Reply to: Is my float sticking? posted by ScottyHOMEy on January 01, 2010 at 10:03:44:
Think of your float just like a toilet tank. Gravity feed systems are VERY sensitive to dirt because there is so little pressure to flush them through
The float if brass could have developed a leak, or corroded the float --to--hinge-- connection so that it no longer aligns correctly in the bowl---a good bump could have knocked it askew, causing it to bind in the bowl, etc
If cork/ replacement/ foam float it could be "waterlogged"
Because it seems to have run OK for awhile, I'd guess the level STARTED out OK, but as above, that could have changed.
Don't fret this. Old carbs are simple, but "stuff happens"
