Posted by Dave H (MI) on January 01, 2010 at 13:41:14 from (64.12.116.73):
In Reply to: Is my float sticking? posted by Faster346 on January 01, 2010 at 10:03:44:
Everything below makes sense to me in regards to the gas running thru the carb to the ground when you are not running the tractor. As JimN beat into me years back...turn off the gas on your tractors when you are done. It just makes sense. What doesn't work for me is the 2 minutes of cranking to get fuel to the carb before it will start. It's a gravity system. Turn on the gas and it is there. With your overflow issue there should be enough gas in the carb to get a start even with the fuel off. I do it every day around here to avoid flooding in cold weather. If it were me I would also be looking for an answer to why a Farmall M that should start in a couple of cranks is not starting in a couple of minutes.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
