Re: Just quit backfires
Posted by d7 fever on January 01, 2010 at 14:04:12 from (71.123.109.251):
In Reply to: Just quit backfires posted by henry warder on January 01, 2010 at 13:46:31:
check to make sure you have compression on all cylinders, make sure distributor hasn't jumped time, take out #1 spark plug turn engine over to top of compression stroke,(top dead center,TDC) check to make sure rotor is pointing toward #1 on distributor cap. try replacing the condenser. check for cracks in the distributor cap. check spark plugs. Start with the easy things first.
Good luck
