Re: PTO power
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Phil Auten (TX) on April 28, 2000 at 04:02:45 from (206.175.72.226):
In Reply to: PTO power posted by Todd Dalecky on April 26, 2000 at 21:00:56:
Todd,
Gadget and Big Fred are right about grabbing that pulley, very hazardous to your health.
Sounds like your governor isn't opening up the carb when the engine gets loaded. Follow the procedure to adjust the governor to carb linkage first and eliminate all the slop you can. If that doesen't help, check the innards of the governor for function, wear and general cleanliness. Lubricate as required. I haven't been into a Cub governor yet, but mine seems a bit sluggish so I may be joining you soon.
Phil
Post A Followup
: Re: Re: PTO power
