Re: Farmall 140 seed plate drive oil seal
Posted by mattofvinings on January 01, 2010 at 16:02:45 from (67.142.161.32):
In Reply to: Farmall 140 seed plate drive oil seal posted by JFay on January 01, 2010 at 13:58:44:
What I would do is to setup the plate on the lathe and bore the hole to the next standard 1/8" size. For example if you are around 2.8, I'd go up to 2.875".
This might be out of the realm of possibilities for some home/farm shops but then you have an easy replacement next time. If you have a friend with a lathe it isn't a long job.
This post was edited by mattofvinings at 16:03:34 01/01/10.
