Re: IH 480 disk doesn't leave the ground level
Posted by tractor300 on January 01, 2010 at 16:40:39 from (173.84.220.81):
In Reply to: IH 480 disk doesn't leave the ground level posted by doug boll on January 01, 2010 at 11:30:12:
I don't know how fast you are going, but a lot of the older disk were designed for a slower speed than the newer versions. Also I have noticed all the guys that disk in the same direction have a lot of ridges in there fields, sometimes as much as 6-8" between ridges and lower spots. I always disk at an angle and that helps eliminate part of the problem. If the blades are worn uneven even as little as an inch will cause ridging. Could be a combination of a lot of things.
