Re: farmal h will not stay running
Posted by John - OH on January 01, 2010 at 17:40:37 from (76.2.225.0):
In Reply to: farmal h will not stay running posted by cornrow on January 01, 2010 at 14:30:32:
Start simple and work from there. Check to make sure that you have a good flow of gas from the tank to the carb. I have had 2 H"s that have had junk in the tank that was partly clogging the fuel outlet. As others have said you are running lean or the fuel is running slow. Start with the flow if its good move to the carb and so on.
Just my 2 cents!
John
