Symptoms indicate a fuel starvation problem, not a governor issue!
When the engine starts surging try slowly closing the choke. If you find a choke setting that causes the surging to go away, fuel starvation is the problem.
Some possible causes:
- Restriction in the fuel line supply (obstruction in the gas tank covering the fuel outlet, plugged sediment bowl, plugged carb inlet screen, etc.) - Blocked carb orifice - specifically the high speed jet - Vacuum leak (look at the carb to manifold and manifold to head gaskets)
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
