Carb leak on 2424
Posted by Tim in New York on January 01, 2010 at 20:32:35 from (24.97.78.201):
I happened to check the barn before bedtime tonight and discovered I had a pretty good fuel leak coming from the bottom of the carb on my 2424. The drip is coming off the big screw at the bottom of the carb.
I used the tractor today to plow - nothing unusual. The tank is less than half full, I did put 5 gallons in it a few days ago.
Any ideas what kind of problem I have, and how I can fix it? The barn floor is wood, so I can"t have gas running on it.
Thanks,
Tim
