Remove the gas line at the carburetor and see if there's a full stream of gas from the tank. Hold a clean container and catch the gas. If this looks like just a trickle check the tank for rust & dirt blocking the flow. Shine a good flashlight inside the tank. If the flow looks ok remove the tube fitting where your gas line connects and look for a clogged screen. Make sure your float is set correctly and is not rubbing the sides of the carb. Check that main jet for being clogged. Hal
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
