Re: Cub hard start
Posted by Dellbertt on January 02, 2010 at 15:12:51 from (209.172.23.97):
In Reply to: Cub hard start posted by J Wilbur on January 02, 2010 at 14:42:25:
Choke it one turn then no choke at half throttle.
Try new spark plugs AC Delco work for me.
Tighten carb bolts.
Check for intake leak.
Check compression.
Run it at night in the dark and look for spark arc.
Dell
