Re: Cub hard start
Posted by Steve Butram on January 02, 2010 at 19:21:48 from (74.126.249.114):
In Reply to: Cub hard start posted by J Wilbur on January 02, 2010 at 14:42:25:
Hard starts at times can be a symptom of a vacuum leak. Not allowing the fuel air mixture to reach the cylinders after you have gas running out of the carb. and no start pull the #2 or #3 spark plug.If they are dry then you have a vacuum leak. Also at times the spark plugs can get fuel fouled so you may want to change the plugs or clean them with some carb cleaner. Also the timing may be off a few degrees off
