Re: farmall A hard to start when going backfires
Posted by Brownie 450 on January 03, 2010 at 04:12:17 from (66.43.241.141):
In Reply to: farmall A hard to start when going backfires posted by brian colborne on January 02, 2010 at 16:11:45:
Mag or distributor? Check that the rotor is lined up with a distributor cap plug wire terminal when ready to fire if a mag is being used.
