Re: 1066 Standard Wide Front End Overhaul
Posted by Michael Sheik on January 03, 2010 at 07:53:52 from (65.255.87.29):
In Reply to: Re: 1066 Standard Wide Front End Overhaul posted by Allan In NE on January 03, 2010 at 07:44:55:
Ah! Man! - I was hoping on you to be one of the ones that had been there done that. I am hoping that the hard part is over getting that steering cylinder mess out of there. I'll check back in after church and lunch.
