Posted by mattofvinings on January 03, 2010 at 09:21:34 from (198.208.159.20):
In Reply to: 300U IPTO Howl posted by Dellbertt on January 03, 2010 at 08:08:04:
Different tractor, similar issue.
460U, IPTO runs constantly. If I disengage it the engine bogs down as if under large load.
I just run it constantly turning although I try to be extra careful as it is a safety issue....I don't think it hurts anything at all (just a shaft turning in ball bearings). In your case the lever position with all the noise would seem to be much worse.
I believe the problem with my tractor is that one or more bands inside the trans are mis adjusted or shot. I have attempted no adjustments at this point.
This post was edited by mattofvinings at 09:34:53 01/03/10 2 times.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
