kossuth said: (quoted from post at 08:16:26 01/03/10) Yep, you just learned a practical example of Ohm's law. IE cables are usually rated by their resistance per foot. You can do some figuring with these formulas to see in reality how much voltage was reaching your starter. http://en.wikipedia.org/wiki/Ohms_law
Kossuth:
You are exactly right. Someone had patched the battery box bottom (and sides) years ago. When they did, they put in a new floor which did not have access for the ground strap. So, they ran a ground cable up to the rear gas tank support - much longer than the original strap which bolted to the center rear deck bolt (from under seat battery box). When I bought the tractor I was in a rush to get it started and loaded, so I duplicated the existing cable arrangement with new cables. So, my tractor had two rather long cables. Not good. I am glad I got my cranking problem fixed, and even more pleased if I have helped others with their problems.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
