Re: starter noise
Posted by gene bender on January 03, 2010 at 10:07:49 from (67.55.226.179):
In Reply to: starter noise posted by W.Schmidt on January 03, 2010 at 07:27:36:
Remove the starter then you can turn the engine over to inspect all the teeth on the ring gear. If there are bad teeth on the ring gear a new bendix drive wont do the best unless it has good teeth to enguage. Mite not be a bad idea to clean the armature and add new brushes along with new bushings on the armature.
