Posted by IH fan on January 03, 2010 at 16:57:24 from (70.250.254.17):
In Reply to: Super C Hydraulics posted by ScottyHOMEy on January 03, 2010 at 09:24:57:
LBM said: (quoted from post at 17:00:39 01/03/10) The tractor does have a fast hitch. I won't be able to use the hitch if I use it this way, right ?
That's right, you won't be able to use them both at the same time. I'm sure there is a way to tap into the system and operate both at the same time, but I'm not familiar with how this circuit works. I do know you could put a flow divider off the pressure line of the pump (I have seen these at TSC) and then add an open center 4-way valve. However, this will always rob flow from the existing system and slow everything down... you probably don't want that. If there is a way to add it to the existing system without the flow divider, that would be better. What you would need is a valve to parallel the Fast-Hitch valve.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
