Sounds like fuel to me too. Check the screen filter in the sediment bowl. Sometimes they get plugged. My SM had a similar problem. It was just junk and rust in the tank. Rust and dirt would settle out, and plug the inlet to the sediment bowl. Runs great, then sputters and dies, choke it and you can limp it around a bit....same same. Might have to clean your tank. Temp fix, but you can shoot some air back into the fuel line and try to knock some of the sediment loose. Worked on my SM for a while, finally had to pull the tank. Check your lines too. I would unhook your line at the carb and hold a can under the line. Crack open your sediment valve, and see how fast the fuel stream is. Should be about pencil thin and constant. Shawn
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
