Re: When did engines start using high detergent oils?
Posted by Zach Bouchard on January 03, 2010 at 19:28:20 from (66.165.45.67):
In Reply to: When did engines start using high detergent oils? posted by Richardin52 on January 03, 2010 at 18:43:17:
People put questions on this on here all the time,and from what i have heard it only matters if it has never used detergent oil. If it never has or if your not sure your best bet is to pull the pan and valve cover and take a look and clean it out. I don't even know if you can still find non-detergent at most places, at leat i have not seen it. Most engines today run typical engine oil, which is detergent in most cases.
