Re: PAGING Jdemaris, another 560 injection pump question for
Posted by george md on January 03, 2010 at 21:40:14 from (209.213.167.201):
In Reply to: PAGING Jdemaris, another 560 injection pump question for ... posted by casered on January 03, 2010 at 20:11:35:
Casered,
More parts to remove before you are ready
to slide the head & rotor from the housing.You
must remove the advance plungers and the advance
ball ( it is screwed into the cam ring),most
likely you will need the spline drive tool to
remove the ball. There is a 7/16 head screw that
is the guide for the governor springs that has to
come out ( springs too ) Under the guide screw
is the metering valve that is hooked to the
governor linkage ( remove metering and the small
conical spring under it). Now you should be ready
to remove head& rotor ,clamp head lightly in vise
and slide housing up off of head ( DO NOT let
housing slide down on head or the body O ring
will pop out thru a hole in the housing ).
Send me an email and I can send you some
pictures of a 560 pump being taken apart.
Allen in ne has my spare tools ,he isn't
using them right now .I can get him to send
them to you and then you return them to him
as he has another pump to do .
george
