Re: Hand Cranking a Farmall H
Posted by sflem849 on January 04, 2010 at 08:36:51 from (66.254.196.101):
In Reply to: Hand Cranking a Farmall H posted by ScottyHOMEy on January 03, 2010 at 12:22:51:
williamf said: (quoted from post at 04:18:36 01/04/10) Starting Crank Pin - IH part number 41966D.
Roll pins come in different strengths. I put one in mine four or five years ago; I use it to turn the crank a little every time I shut the tractor down as an alternative to getting a new ring gear. It shows no inclination to bend.
Good luck, Wm
Another dirty trick about roll pins is you can take a smaller one and jam it inside the big one. This will make for a much stronger pin.
