Re: M Crank Removal
Posted by Andrew Z on January 04, 2010 at 09:25:02 from (64.252.44.45):
In Reply to: M Crank Removal posted by ChrisMO on January 04, 2010 at 09:15:39:
you need to split the tractor (remove engine from tractor) to get the crank out. The reason for this is that you cant get the flywheel off or back on and you cant get the front off due to the timing cover and front pully. as far as installing bearings at low temps, i would say if the bearnings themselves are the same temp as the crank and cast parts then it should be ok. just keep in mind that if its really cold steel becomes more brittle and easier to snap.
Andrew
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
