Re: Who would of thunk
Posted by pete 23 on January 04, 2010 at 10:57:11 from (173.87.15.32):
In Reply to: Who would of thunk posted by thresherman on January 03, 2010 at 17:54:58:
I never had much use for the .002 bearings . In fact, I have replaced them with std bearings a couple of times to get correct clearance. Too tight is just as bad as too loose. Oil throw off from rods is what lubes the cylinders and clearances must be in proper balance. Also, the throw off for lubrication is why you never want to let an engine sit at low idle for extended periods of time. Between the rich idle mixture and poor lube from bottom it will sure shorten an engines cyl life.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
