I've rebuilt many HD diesels that always had been run with high degergent oil and many were absolutely spotless inside.
Add to that my 87 Chevy Suburban with a 6.2 diesel. Run on Shell Rotella for 520,000 miles before it blew to pieces. That due to a main bearing web failure. Pulled it apart an it too was absolutly spotless inside. None of the "crud" you mention anywhere. Clean oil pan bottom heads and valve covers.
Not all degergent oils are equal in detergency, and you didn't mention any specific engines or oils. I do know that the engines I've torn down that were used with Shell Rotalla or Deere TorqGard were spotless inside - even after very high hours or miles. On the other hand, engines that had been run on Quaker State HDX tended to be a little grimy inside - especially Detroits.
I never heard the "wives tale" of 12 volt ruining a 6 volt starter though. It was standard knowledge that it worked fine in any shop I ever worked at. 6 volts will certainly ruin a 12 volt starter though.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
