I believe most of the hype about detergent oil in a cruddy engine hurting it are from changing to detergent, and then running the old interval before changing again- if it's cleaning up the crud, you've gotta get it out of the engine. If it's cruddy in there, the oil will start to get dark right away, like diesel does, even if it's a gasser- when I'm cleaning one up, I always change the filter after a couple warm-ups to make sure it's not clogged and bypassing, and then watch the oil color, and change it when it starts to get opaque- usually takes several changes, and yes, Seafoam is my friend. First couple changes will come pretty quick, then slow down as the engine gets cleaner. And I have to agree with some, if you've changed the oil regularly when you should, with good detergent oil, the engine will be pretty darned clean inside when you pull it down
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
