Re: 10-20 steel wheels
Posted by charlie M on January 05, 2010 at 06:33:53 from (70.101.104.228):
In Reply to: 10-20 steel wheels posted by Tony S. on January 04, 2010 at 19:28:50:
I had that done with the front wheels of my W30. Trick is to get the rims centered and have a good welder. I have a good set of 10-20 wheels with tires if you are interested. I'm around the Rochester NY area if you are interested - drop me an email.
