The Worksaver hitch works ok. However, be aware. You have no draft control. The lift capacity is only around 500 lbs. And the lifting range is limited. The top link is short and this limits the lift range and also makes implements tilt when you may not want them to. I would not attempt to use a plow. A carry all, light cultivator, small disk, things like that will work OK. The PTO is offset, so with a bush hog, there could be interference problems with the PTO shaft. You also must use a cross bar in the lift for drawbar work as when the 3 point is on there, the drawbar is off. The sway brace is somewhat cumbersome. I successfully used a post hole auger, but the auger hitch must have an adjustable top link bar to shorten it up so you can lift the auger high enough. The auger did work good though because you have down pressure. Being aware of all this, the 3 point can be quite useful on the 140 but you must know the limitations and learn to live with them.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
