Re: SUPER M-TA GASKETS
Posted by Andrew Z on January 05, 2010 at 17:49:06 from (64.252.44.45):
In Reply to: SUPER M-TA GASKETS posted by P.Leffelman on January 05, 2010 at 17:11:48:
Manifold gaskets are still out there from Case IH i just ordered a complete valve grind set for m Super MD from Messicks. As for the valve call some salvage yards, Steel Wheel Ranch and others will have that part.
I looked under 400 diesel for the parts. (same engine as the SMDTA)
Andrew
