you could have a problem with one of your cables if starter motors good when bench tested,double check grd connections also clean starter to bell housing surfaces, get a good cable try replacing one cable then the other, if this doesn't work check starter switch if it is pull type,if it uses a sol. bypass it by removing one cable from sol.terminal and touch it to the other,don't forget that the cable from sol.to starter could also be bad, BE SURE TRACTOR TRANSMISSION IS IN NEUTRAL be patient it is something simple
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
