Re: water in the trans
Posted by bc on January 05, 2010 at 18:46:33 from (71.158.222.215):
In Reply to: water in the trans posted by cazzhrdwd on January 05, 2010 at 17:41:17:
When you burp your transmission, make sure the fill plug is tight so the tranny has no vent. Then when you pull the drain plug, have it ready to stick back in. It will only want to dump a quart or two before it airlocks for a split second and long enough that you can restart the drain plug.
Unless you are having hydraulic problems, I'm not sure it does much good to change the oil in the winter. Just get more condensation in it. Keep the snow and ice away from the shifter. Find a bucket or something that will cover the shifter. You want to keep the rain off of it starting in the spring.
