Re: Where to start on a 1943 M
Posted by soybeanjoe on January 06, 2010 at 15:48:20 from (66.213.171.108):
In Reply to: Re: Where to start on a 1943 M posted by Charles Tichenor on January 06, 2010 at 06:56:15:
Easiest is to remove the tank & flush out with fresh gasoline. That will usually get out much of the old gas that has gummed. I once had a tank that had a lot of gum in it & someone suggested throwing rocks in it & tumbling the tank. Problem was the rocks stuck in the gum & stayed there while tumbling. I ended up putting fresh gas in it & let it sit for several days. I then tumbled the tank & drained the gas out. It had dissolved most of the gum & the rocks came out.
I have also heard of guys pressure washing the tank though I personally haven't tried it. If you do pressure wash it make sure you get all the water out before you put it back on.
