Re: F20 Head bolt torque
Posted by Dave in NY on January 06, 2010 at 17:04:52 from (67.242.134.10):
In Reply to: F20 Head bolt torque posted by Indiana Boy on January 06, 2010 at 15:19:45:
I had trouble with anti-freeze weeping a tiny bit after getting it up to running temp.I had torqued to 90 ft.lbs.Next day motor cooled off, I re-torqued head to 90 ft. lbs. and then re-set valve lash, also re-torqued nuts on manifold.I had to remove rocker shafts,rockers to get wrench and socket on all the cyl. head nuts.I wouldn"t even bother putting valve cover back on till you run it and then re-torque,set valves.You will have best results setting valves while motor is hot.You can do it while its running but kind of a pain in the a--.This might sound like a lot of monkeyin" around but its really not that bad.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
