Re: Replacing a Charlynn output shaft coupling on an H
Posted by soybeanjoe on January 07, 2010 at 05:01:09 from (66.213.171.108):
In Reply to: Replacing a Charlynn output shaft coupling on an H posted by nt moore on January 06, 2010 at 18:37:56:
Like David G said, there is a seal at the back of the sector housing where the shaft goes in. If it's leaking there while you have the shaft out check it for wear. Sometimes the shaft is worn & a new seal won't stop the leak, BTDT. In that case I have put the seal in backwards to get it off the worn place & in one case put 2 seals in, inner in backwards & outer in normal.
Front plug doesn't have a seal, pipe plug that seals seals itself when tightened, but I had one that would leak. Ended up having to put a new plug in.
